After 39,000 miles in my 2011 GTS, I received a RED "Transmission Emergency Run" error message which effectively brings the car to a halt and then no power.
The manual guide advises having the car towed to the nearest OPC. In my case I switched off the engine and waited a few minutes after which the car started and performed normally as if nothing had happend.
The following day I drove 75 miles home with no further events. Previously I have had two 'transmission hot' messages which both disappeared within 20-30 seconds.
I am taking the car to my local OPC tomorrow for diagnostics but having checked various forums the outcomes vary from requiring a complete new PDK gearbox to replacing an aging battery or a PDK heat Sensor or PDK software upgrade.
I don't currently have the extended Porsche warranty, but if this is becoming a common problem I will be once (hopefully) I get the all clear!
