jonnyporsche
Transmission noise help. For the last year I have had a metal against metal spinning noise from the clutch when the ignition is cut. From past experience this noise is a worn thrust bearing which sooner or later needs to be replaced, but not being too eager to start dis mantling the clutch,( not exactly an HB Viva), am I right in my presumption.
