I have purchased a trickle charger to condition the battery as I will not be using the car much going forward. I was under the impression that the 996 had a "hot" lighter and I could attach the trickle charger to this. I have subsequently found as mine is an earlier 996 (3.4) the lighter is not hot hot but is active when the ignition is on.
The charger has clamps to attach to the battery but as the car is outside I really wanted to use the cigarette lighter. Is it simple to make the lighter so it is permanently on and i can use the trickle charger through this?
Thanks in advance
Thanks in advance
