Trouble getting Reverse
garyandjanet
Starting the car this morning had trouble getting reverse (gear stick kept slipping out)
Once the car was warm , no problems at all.
Anyone have any ideas.
Try selecting first, then pull away for an inch, prior to selecting reverse.
If this doesn't work, Scouser's prognosis is most likely the trouble.
Mine does that. Found it difficult this morning. Select another gear and then reverse but pull clutch out as you select reverse. It's just cold.
....otherwise its a linkage problem[&:]
Si
996 C4
Thanks guys
However the problem looks like its getting worse, so in the gear linkage covered on the extended warrenty ??
Thank you in advance
