SimonExtreme
OK. I know I have only had the car 5 minutes but it is clear to be that the current 292bhp and 260lbs/ft of torque just aren't enough [
]. So where do we go from here?
As I see it, the limiting factor with my current set up is that the injectors are only good for 300bhp and the ECU won't handle bigger injectors. It seems that the "established" option is to fit bigger injectors and fit a Motec ECU. The next limit seems to be the amount of air you can get in and out and that puts a limit at about 325bhp and 300 lbs/ft.
I don't want to open up an engine which has been leak tested and shown to be very good as well as not using/losing any oil (touch wood). I don't want to get a blower either. So, is 325 bhp the max? Is there any other option to Motec?
