turbo 2 do they slightly smoke on start up
- Thread starter Guest
Anyone know how even the pressure should be from the two exhaust pipes. I have noticed that on cold days only one of the exhaust pipes smokes (water vapour). When looking from behind it's the right one.
Any ideas?
Here is a link to an LE exhaust system (hope this works) which will give you an idea of what I mean - http://www.9mracing.co.uk/html/modules.php?op=modload&name=Shop&file=index&req=viewproduct&productid=404&category=204&parentid=2
Ian Donkin
You won't be able to see it for long as the turbo should be miles up the road within seconds[
That would also explain when the right foot is planted the exhaust noise changes dramatically.
Ian - "You won't be able to see it for long as the turbo should be miles up the road within seconds" how very true !
Ian Donkin
