Yeah, they all just need gassed.....................[
Yes, I done this a while back, paid about £350 for a recon compressor at that point, about £100 for a good SH condenser, £25 for a receiver/dryer with sight glass. Only replaced the seals I needed to for condenser and compressor fittings. Vacced out the system, 10ml of Ester oil added to the system then filled with 850 grams (30 oz in old money) of R-134a and all has worked well in my icy cold world since!
I've actually needed a further good SH condenser in that time, as it sprung a leak at the connector end, they are right in the line of fire for road debris there, this time I have sprayed that area in stone chip to add some protection, today's top tip!
Another top tip is don't over tighten the drive belt, as it puts strain on the compressor nose seal, another common fail point.
I started from a base of a sieve like condenser, replacing that made the system leak free. Although upon running it became evident the compressor nose seal was also leaking. They would be my starter for 10 points to check. You will not need to bother with anything else unless you are unlucky!
Stuart
