Turbo engine bay fuel lines.
- Thread starter blade7
scam75
Well-known member
It's about £100 delivered from Paragon Parts. You need to take the wheel arch cover off and cut both metal pipes about 8 inches before they enter the engine bay, it connects there with compression fittings and then a screwed connector in the engine bay for the feed and a pop on with jubilee clip for your 3 bar FPR return line. It's aeroquip hoses and a good quality bit of kit. If you have a standard 2.5 bar FPR you can specify a screw on fitting.
Porsche 944 Fuel Line Kit
blade7
Well-known member
scam75
Well-known member
scam75
Well-known member
As much as that burned, the WG got a good clean up, it was quite horrible inside, and it is now all shiny and back together with a brand new diaphragm, and then a £7.50 MBC solved my problem
blade7
Well-known member
Yes I saw that, $65 postage bumps the price up to £134. The standard low pressure hose has threaded connections on it, I'm just waiting for confirmation that the Paragon will supply with one clamped end.You don't pay duty on anything less than £135 from the USA, so maybe they don't bother with the VAT either because of the number of items they have to deal with?
scam75
Well-known member
The Rennbay lines can come with screw fittings on the other end, so you don't have to cut the hardlines. They haven't told me what they cost yet though.
You would be leaving the old hard lines in the engine bay doing that, leaving a potential engine bay leak that could spray onto the engine if they fail. By going into the inner wings with the new rubber lines, you would eliminate that. My thoughts anyway. Seems to be the main reason for putting the new rubber lines down into the inner wing and obviously replacing the old rubber lines at the same time.
A failure on an old hard line in the inner wing will not chuck fuel into the engine bay.
I see what you're saying but if you hard lines are in good condition then I think this is a little over cautious. I mean there are many other potential failure points for fuel leaks in the engine bay, the injector seals, the lines where they attach to the fuel rail, damper and regulator. You could say that the rennbay method is dangerous as it doesn't use a flared pipe joint like the factory hard lines. I know we have all seen the horrific pictures of 944 engine bay fires, but I'm pretty sure that the majority of those are from failure of the rubber lines rather than the mechanical flared joints at the hard line. Not knocking DIY AN hoses, but I'd imagine there have been some fires because of incorrectly assembled ones (or unknown, unbranded hose failing in contact with fuels containing ethanol).You would be leaving the old hard lines in the engine bay doing that, leaving a potential engine bay leak that could spray onto the engine if they fail. By going into the inner wings with the new rubber lines, you would eliminate that. My thoughts anyway. Seems to be the main reason for putting the new rubber lines down into the inner wing and obviously replacing the old rubber lines at the same time.
Edited to say that on RHD models at least the clutch line from the fluid reservoir is another concern for fire safety as one of the forum members unfortunately found out...
