The idle on my turbo confusing me. when cold it idles at 1000 however when warm the idle increases to 1300. Had a look at the manual it should be 950 ish. I'd have though the idle should be higher when colder and lower when warm. Any thoughts as to what the problem could be. When i open the window theres a strong smell of fuel could this be related to the high idle. The MOT station said it's not running rich, which has confused the issue more. Any help would be appriciated
turbo idle
- Thread starter Riggernut
Diver944
Clarks Garage has a simple guide to adusting the idle here:
http://www.clarks-garage.com/shop-manual/fuel-08.htm
The car needs to be warm and the idle stabiliser valve (ISV) needs to be disabled. If you set the warm idle to 950 and it drops to an incredibly low figure when you next start from stone cold I think it could point to a problem with the ISV, or some leaks in your vacumn pipes
http://img.photobucket.com/albums/v313/zeddy3/image018.jpg
had a look for leaks found a split in this rubber hose close to the jubilee clip
could be the culprit, cheers
