John Ware
The symptom is that the engine just stops very occasionally at idle whilst moderately warm. I haven't had the opportunity to stick the car on a tester so no clue about fault codes (will be serviced end of Apr, early May so hoping to hang on until then).
I suspect either the MAF or the coil packs, but there's no CEL and it seems to run smoothly the rest of the time. Any clues, please?
Also, the suspension is creaking just a little bit so will probably look to having that sorted this year. I presume bushes of some sort.
