Turbo oil cooler.
Big Dave
Hi folks
Has anybody got a oil cooler from a 944 turbo [ 250bhp ] that is off the car.??
Im after the dimensions of one, incl number of oil rows , depth width + height...
Do you know IF they are larger than an S2 one..??
Im looking into fitting a twin cooler set up on my S2 + wondered if a twin turbo cooler system might work...
Only reason for a turbo one ,, is there mounted differently to the S2 , with ducting to the cooler .
Im trying to get some room under the current S2 one for some air flow for brake cooling aswell...
Look to Mocal for many types of oil cooler but if you need a bespoke one I cannot recommend highly enough this company's fabrications.
Top top quality. Ask for Peter.
I have one in a box in the garage. Not only can you measure it, you can own it if you want to.
Blimey Dave, how hot are you getting the oil in your Normally Aspirated motor????
Mind you I imagine a Supercharger might increase the temps a bit [;)]
