scam75
Well-known member
Evening All
Quick question for turbo owners. Where does the banjo bolt/pipe route to that is on the left side hard pipe? I presently have the banjo bolt and pipe in situ, but only about 3 inches of pipe, then what looks like it should be connected to a vac pipe, is missing. There is a jubilee clip on the end of the open pipe which looks like it used to hold a vac pipe in place. Ive had a quick root about in poor light and not found the culprit. Pretty sure something should be connected to it as the hard pipe is currently venting to air. The cycling valve is disconnected and has been for some time but i'm certain this should not be an open pipe! Car currently not running which doesn't help diagnosis. Having fuel pipes replaced.
Thanks in advance
Stuart
Thanks in advance
Stuart
