![rsp295b.jpg](https://i.imgur.com/rsp295b.jpg)
This is a job I usually did myself at one time, but I'm less inclined nowadays. The thought of scrabbling around beneath a car, hot oil dripping on my neck and then having to find somewhere to dispose of the old oil and filter no longer fills me with the ambition it used.
![Woozy face :woozy_face: 🥴](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f974.png)
There's little doubt the cost of this process has increased substantially over the last few years with many threads here reporting on horrific charges for this work. Here's what it cost me for what it's worth and may be helpful to others.
The filter kit I purchased direct from my PC. Warranty dictates a Porsche approved oil filter is used. You can get the 10% Club discount, of course. Oil is worth shopping around for since prices and supply seem to vary a lot. I originally ordered from a Yorkshire firm recommended by a forum subscriber, but this outlet was unable to supply for 3 weeks. The particular oil I required seemed in short supply atm since several of my usual suppliers were also out of stock. 992's are now fitted with gas particulate filters and need special green label Mobil 1. Anyway, I eventually took a chance and bought off Ebay and was lucky. The order went in on day 1 and the correct oil arrived the very next day - so happy days and all was well!
![Thumbs up: medium-light skin tone :thumbsup_tone2: 👍🏼](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f44d-1f3fc.png)
Oil (10 litres) £112.25 (delivered)
Filter £25.01 + VAT
'O' ring £6.17 +VAT
Sump plug £5.32 + VAT
Labour £50
Grand total £206.05
Draining the oil hot means you'll need 8 litres of fresh oil to replenish, and will then have around 2 litres left for future top ups. In practice, try putting in around 7 litres, then drive the car until warmed up. The dashboard oil gauge may not register right way, but once warm and with the ignition turned off and on a couple of times, you should see the level on the PCM gauge and can calculate how much more is required to fill. Difference between min and max on the Turbo 'S' PCM gauge is around 1 litre (1.3l on some other models).
Take care not to over fill though.
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f609.png)
![7XWf5Af.jpg](https://i.imgur.com/7XWf5Af.jpg)
Regards,
Clive
