Turbo sill skirt....where can I get one?
- Thread starter Hilux
Hilux
If you mean the black plastic trims under the front wings/sills then be prepared for a shock...
They are available from the OPC, fronts are £86+VAT each and rears are slightly less than that.
Hold on one cotton picking minute Fen, are you seriously saying OPC charge that for the tiny little front wing one and its MORE than the main (long) one?
Sheesh.................
The metal mounting bracket is a seperate part - I replaced the S2's rusty ones with new. Not cheap, IIRC.ORIGINAL: Fen
The front one has a metal supporting bracket as part of the piece which I guess is the reason
Cheers,
Jim.
sawood12
Hilux
bolted into the wheel arch lining
Mine has two metal brackets with holes that hang down from the sill.wing bottom ie: vertical. I assumed that the sill section simply screwed or bolted onto these.
sawood12
