Turbo tie rods
- Thread starter Jacob
bones
http://www.type-911.co.uk/
http://www.berlyn-services.co.uk/parts.htm
to see if they have the correct parts at sensible money. As to the job, it apparently makes for a more responsive setup. I would have thought two-three hours labour and a prees might be necessary, if you are doing this job it's a good idea to renew other bushes too. Once you have them fitted pereodically check the gaiters are still attached like drive shaft gaiters they have a tendency to work free and loose the grease inside.
After I had them fitted, I noticed that the steering was more 'solid', with less chatter, but more feel for what the tyres were doing (less masked by the chatter).
Not very informative words, but the best I can do. I think the cost was worth it, and wouldn't like to go back.
As I remember, about ÂŁ100.00 for the parts, and 2 hours labour (not by me, I may add),
including a simple wheel alignment.
So, ÂŁ180.00, perhaps ?
I think that I had it done with other work, so can't be sure.
Of to Le Mans soon (approx. 10 minutes - not in my car, though).
dixhuit
Had the turbo tie rods fitted about a month ago. Initial reaction. Has lightened up my steering (mines a SSE so running turbo suspension, big rims ,tyres etc but is fitted with standard 3.2 steering) which was heavy before. Much more positive and was recommended as I wanted to fit a RS smaller diameter steering wheel. Well worth the relatively minor expense as I would have needed to spend some money fairly soon as one linkage had some play in it but not enough to fail the MOT.
Cant answer the spanner question as my specialist made the suggestion and did the work
Simon
Richard Savage
I've been advised to have the geometry checked / reset on mine. What are you expecting to pay?
R.
You're probably right RB. When I spoke to my local independent about it he said "All the track dayer's are having it done so there must be something in it, they reported back that they could feel the difference." That's why I put it on my list.ORIGINAL: Richard Bernau
IMHO its a waste of money unless you need to replace the OE tie rods. It was recently voted one of the most overrated upgrades on Pelican. I couldn't feel any difference when mine were done, but I was getting a new steering rack anyway so while you are in there....
I think the sad truth is that there isn't much wrong with the std front suspension provided its all as new and in good working order. I say this having replaced everything [&:] Replacing worn old stuff with new will always feel better, tighter, more precise. Unless you are creating a track car and taking lots of rubber out of the suspension, I simply wouldn't bother.
Maybe its just the placebo effect and having spent out a couple of hundred quid nobody really wants to admit it made no difference.
Had a similar conversation with him about bushes (the suspension variety). In his opinion new OEM rubber ones are perfectly fine for fast road use and much more comfortable to live with.
I had the Turbo tie rods done recently and I noticed a definate improvement in the steering response.
However .... I had also had 4 new Carrera Club Sport dampers, new front and rear anti-roll bars and new (turbo) rear torsion bars, the car lowered and complete suspension setup, all courtesy of 9 Meister, so....
It's very hard to say exactly what was responsible for the improvements
It sounds obvious but I think Richard's point about new components is easy to forget, god knows how old my old tie rods were, they were probably just worn out !
911 SC Sport ( slightly modified )
Basically it feels like I'm steering the car directly rather than wait the car to catch up with what I've asked it to do.
It feels lighter too ( but this may be down to the front suspension improvements ).
I think in light of what I've read I'll keep an eye on things and only change over to the turbo ones when mine are on the way out.
Well worth it IMO. Steering is slightly more connected, more feedback through the wheel.
