Turbo Vacuum Hose Tidy Up
- Thread starter John Sims
I believe that is the original layout (as it left Porsche) and just goes to show how much extra rubish is as a result of the vapur purge system. [
There is a variation of that drawing, done by somebody on Rennlist, that is a simplification - less pipes less chance of leaks.
	This be the modified version, to save zapping backwards and forwards.
	And this being the original Porsche Plumbing version.
There is obviously some significance to the Y shaped thing that links between the Idle Stabiliser and brake booster, but I cant see what it would be.
sawood12
Just a point of observation. For those of us with 220bhp turbo cars I seem to remeber we dont have the manifold input that is between branch 2 and 3 of the manifold. Therefore where does our brake booster get it's input from?? Maybe that funny Y-shaped thing relevant on the 220bhp cars only as the line into the brake booster is dotted so is probably only connected on the 220bhp cars. The 250bhp cars maybe get thier input direct from the manifold???
By the way how do I extract the pictures from the note? right click/save picture as doesn't seem to work.
I also think the brake booster check valve is that little blue and black valve on the line to the brake servo - the drawings don't show the servo, again for clarity.
The Y shaped thingy I was referring to is the bit of pipe (referred to in PET as a manifold IIRC) at the bottom right of the second drawing. There is also a bent T pipe that can be dispensed with in scheme 1.
	Generaly a far better illustration of the simplified installation but I still remain concerned about the significance, and effect, of removing the Y and bent T shaped thingys. Why would they be there in the first place?
ORIGINAL: John Sims
.........The Y shaped thingy I was referring to is the bit of pipe (referred to in PET as a manifold IIRC) .......
I lied, it is apparently a venturi pipe. So it is obviously for veturifying.
	ORIGINAL: Fen
..and is therefore the "venturi delete" mod Rennlisters talk about. .....
It would seem that it is. And an order has been placed with Dave Linsey for just such a beast. I could get the pipes direct from my OPC but I can't work out from PET which pipes I need.
You do have a "Laust" vacuum manifold, don't you John? With that all the connections can pretty much be run direct from the manifold.![.    [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
ORIGINAL: sawood12
And what exactly is in the venturi delete kit? Is it not just a case of removing it and the T-piece and connecting up the vacuum hoses as shown in the diagrams above?
I can see where you are comming from Scott but the main point of the tidy up is to remove leaks and potential leaks. If I can get one new formed pipe that goes from A to B that has to be better than several original pipes with bits put in the middle.
Apparently, the venturi system wasn't used on later cars - so yet another Porsche "lets try this... oh it didn't work" development.
The appropriate pipes apparently look like this:-
	If I could work out a convenient, and safe, way of blocking off the fuel vapour purge pipe then that lot will be comming out as well.
Fen,
I do have a "Laust". Who doesn't these days? [
