Grr. Here I am about to pop down to Daytona Bodyworks and despite a faultless run down from the North last night, and no history every of reluctant starting in the 6 months I've had the car, it won't turn over this morning. It just makes a relay / solenoid style 'clunk' and that's all. The immobiliser is disarming ok, or it wouldn't even be doing that. Tried a booster battery on it, connected directly to the car battery, no dice. The battery was new when I got the car, and has been conditioned fortnightly so I would be surprised if there is a sudden fault in that. The voltmeter reads a shade under 12V at rest, and dips fractionally when the clunk comes in.
I'm guessing wiring, or a faulty solenoid, or the starter's burned out a pole, maybe. I'm away from base with no tools so there's probably not a lot I am able to do, and it's not parked ina position where I can try bump-starting it. Might have to get the Cambridge OPC to recover it on Monday and do expensive things to it.
Still, at least I'm not stalled in the middle of a level crossing with the klaxons starting to sound...[8|]
