tyers sunroof
Hi
1st time on a forum so cut me some slack.
Just bought my 1st porsche a 944 Lux came with all the right paperwork but know manual
On the way home I could feel the ass end drifting a little on cornering, On checking found the back tyers probably a bit under inflated.
My 1st question, what is the corect tyre pressures for the front and rear. I stuck a shit load of air in and it seem a lot better but would like to have the correct settings.
2nd questing how the fu*k do you get the sun roof out, we found the clipd on each side but dont want to break anyrthing so thought Id ask.
I did buy a Haynes maintanence manual but that only good for stopping the table form wobling
Many thanks
Gary
With the key in the igntion, but not switched on, the 924 would retract the roof arcs, releasing the back of the roof, upon rocking the roof switch to the appropriate position. The 944 will either be the same or will require the moving of the key to position 1(see drivers manual) with the same technique on the rocker switch.
