Tyre Pressure advice needed
- Thread starter Guest
ORIGINAL: poulton
Decided to upgrade to 17" wheels on my 1986 Lux. Going with 225/45/17 tyres on the front and 255/40/17 on the rear. Anyone know what sort of pressures I should be running ? [8|]
What size are your front rims? I've just gone from 205's to 215's of a 7" rim, I was a bit dubious of going wider on that size rim.
Remember a year old thread from a lux guy losing loads of water? I suggested the pipes coming from the intercooler!!! Just checked Brooklands pg 16, Motor mag Oct.17 1981, theres a diagram of what old lux chaps refer to as the intercooler. There was much derision at the time from Turbot chaps about luxs having "intercoolers". Maybe a difference in terminology but I just knew the info came from somewhere!
Will try to find piccy of SCZ wearing BBS.
ORIGINAL: scz
.......Remember a year old thread from a lux guy losing loads of water? I suggested the pipes coming from the intercooler!!! Just checked Brooklands pg 16, Motor mag Oct.17 1981, theres a diagram of what old lux chaps refer to as the intercooler. There was much derision at the time from Turbot chaps about luxs having "intercoolers". Maybe a difference in terminology but I just knew the info came from somewhere!
That'll perhaps be the heat exchanger then. Luxes have a heat exchanger which IIRC comprises a water matrix which kind of sits in the sump; it helps to speed up getting the oil to operating temperature. The seals for this matrix were found to be faulty on early cars and were subsequently changed for a revised seal which was green in colour (Not that Porsche ever produce seals with a history of failure though). If these seals are the old type, or have failed through age, you can get water in your oil.
Don't take all of this as gospel as it is a few years ago I had them replaced on my Lux. I haven't looked to see if the heat exchanger was continued into Turbots and S2's.
mik_ok
ORIGINAL: poulton
What does the 968 castor mount do & is it easy to upgrade to rom standard ? Thanks
Have a quick look at this thread (I've sent you straight to page 3 as there is a huge amount of waffly banter on pages 1 & 2 [&:] CLICK HERE
They make a big difference to the tramlining.
The only thing I'm not sure of is whether they will suit your car? I know early cars had different wishbones..... but I'm afraid I don't know enough to advise you.
