Normal drive today and all well with the tyres and pressures. Got home and parked in the garage and then the TPM Yellow warning came on telling me the O/S/R was down 6psi. Checked the tyre manually with a Tyre Pressure Gauge and it was showing the usual 36psi (same as the N/S/R) which was the same as shown on the dash TPM display. Checked again an hour later and still the same. Tyre pressure fine, but the yellow warning still showing. Any ideas please on how to clear the warning which is clearly spurious. Thank you.
Tyre Pressure Monitor
- Thread starter DRDT
Reset tyre type to Winter. Switch off, switch on, reset tyre type to Summer.
May need to be done whilst driving, but in these circumstances, skip the switch off/on bit
