Tyre pressure monitoring 911 turbo
Hardy911
Tyre pressure monitoring sensors
Can anyone tell me if
Gen 2 sensors 997606 021 20 work with Gen 1 997 606 021 00/01 sensors
How long can the learning process take
According to the Workshop Manual:
There are various types of wheel electronics available.
The fundamental difference is in the TPM generation (1st generation up to 2008 model or 2nd generation from 2009 model onwards) and also in the frequency (433 MHz or 315 MHz).
1st generation TPM wheel electronics up to 2008 model are not compatible with 2nd generation TPM wheel electronics as of 2009 model.
If wheels with 1st generation TPM wheel electronics are fitted on a vehicle with 2nd generation TPM wheel electronics (or vice versa), the TPM system will not recognise the wheel electronics. The TPM system is not active and a corresponding warning message appears in the instrument cluster. In addition, the wheel electronics are reported as defective in the fault memory of the TPM control unit.
Hi Richard ,
Thx for the advice newGen 1 sensors fitted and TPM burst back into life almost immediately .
No need to get fault cleared.
Thankyou
