Tizzy
Doing a few miles in the 944 2.7 now and really getting to know the handling etc. Lots still to do but two hopefully simple questions:
1. Front tyre pressures - 15” wheel 195 tyres. Handbook and car sticker says 29psi. However turn in when pushing on seems a little soft and understeery. Shocks are new so wondered if anyone has had similar and recommeds a higher pressure? I’m going to try 32 to see if there’s much difference.
2. Coolant level. Like almost all 944’s I’ve seen, my expansion tank is so discoloured that it’s imppossible to see the coolant level between min-max. As I have a slight coolant leak anyway I’ve been topping it up to a level that you can just see it under the cap, but don’t want to overfill. I’ll replace the tank eventually as I’ve seen new ones on the Internet for a not inconsiderable £120! But again any suggestions for how full it should be when viewed from the cap much appreciated!
Many thanks
Chris
Many thanks
Chris
