Tyre Pressures - help?
- Thread starter Guest
ORIGINAL: buckie
Hello....
My C2 has the 18" turbo alloys, was trying to find out what the correct tyre pressure should be, front and back??
Help?
Thanks []
there should be a sticker on the inside of the door b pillar with the data ?
Keep them on OEM pressures
38F3E1
36F and 44R are the official pressures for the tire sizes you have posted. Note you have the 996 sized tires on the rear (285/30/18) rather than the 993 sized tire (265/35/18) but they are interchangable and 285/30 seems quite a common fitment on 993s.
Also if a pre 96 car you may need to retro fit the steering brace on the front to fit 18" wheels - think the details are in the FAQ or technical section.
Ian.
sidned
I was wearing the centres of the rear tyres at 40 as well (I am wearing 285/30/18 on the back) and I've found 36 all round works best after 2 years of trial and error. I also found the rear felt more planted at these pressures. Just my 2 cents worth!ORIGINAL: roddylennox
I researched this a few months ago. I think that Maurice has got it right (again!): 36F 40R feels best & is likely to lead to your tyres not wearing the centre tread out prematurely. 44R is too high IMHO.
Try a search on the subject, you'll bring up many opinions![]
ORIGINAL: sidned
Interesting. Thanks sidned. I think I will hear the hiss of air coming out of my tyres shortly. No rude replies please! [][][][]
