Tyre pressures on 18s
RSGulp
Recommended tyre pressures on the following 18s?
Fr 225/40 18
Rr 265/35 18
Cheers [:)]
ContiSport N2s. Used to use 36psi all round on 17 Bridgestone SO2 - should I do the same on 18s. Fast road use. [;)][;)]
ORIGINAL: RSGulp
36 psi on 17s IMO way too high for FAST road use, that´s for standard road use. FAST road use is almost like track use, i. e. 26 rear / 28 front cold tyres, will make 35 psi on hot ones all round. I don´t think 18s will make a big difference in pressure.
On the other hand, you can easily use 36 psi for fast polish use, no problem.
Rgds,
Hacki
I don't think Rich's FAST road use is the same as track use Hacki[:D]
(will ring you tomorrow Rich)
Rich, some info for you about road pressures from the Porsche/Michelin guide for you here:
http://www.porscheclubgbforum.com/tm.asp?m=401212
Rich
If you plan to run 18" on the road, then I suggest 2.5 bar in the fronts and 3 bar in the rears (or 36 and 43 or thereabouts). 36 all around is for road use on 17".
Damen
