Tyre Pressures
- Thread starter Guest
However, the DRIVERS manual suggests 44psi rear and 32 front ? (can' t remember the latter) Seems way to high and I and others have successfully and more comfortably run 36psi (cold) all around on both C2 & C4.
Melv
Diver944
I now run at 32psi front and 36 rear which brings an even wear pattern.
Many theories for this on the 944 Register but the one I like is Porsche have recommended these pressures to stop blowouts when running over 150mph on the Autobahn. At those speeds the tyre will overheat if the pressure is too low.
Any other ideas?
Elliot Davies
oldtimer
PS on the track a little less pressure in the front helps reduce understeer , however on the track its the rears that tend to get really hot and 'balloon'....you might detect the effect....for an average driver and a standard car 36 all round is good enough.
Jeff Forsyth
Jamie
fastlane
ORIGINAL: Jamie Summers
36psi cold all round - standard spec for 964 on 17"
Jamie
+1
Jamie
ps Just remembered, it's the car in my avatar (d'oh !!!!)
