Tyre Pressures
- Thread starter TISPKJ
Dont forget to pump them up againg to come home, i found even 50 miles in normal road conditions wears the inside on these Toyos badly .................
After speaking with Steve at Simply tyres, he suggests running the at higher temps as apparently they have a stiffer sidewall.......This seems to be the case, many of the Gt3 boys are running even higher hot temps...(extra weight perhaps?)
So, on this basis I have been running the Toyos at 33/4 front and 36/7 rear (HOT) , happy with the handling and even wear.
For the sake of the sidewalls I tend not to go out with reduced pressure in the tyres, prefer to go out for a couple of steadyish laps, get the pressure up then let it
back down to hot target levels....I have to say the Toyos do seem need a few adjustments to get right, but fine when you get there.
I do recall Mark W who logs on here as MTBR, checked 888 pressures using his pyrometer and in conversation I am sure he arrived at F33/R36 hot to give an even temperature across the tread, this was one of themain reasons I went with those settings.
Paul, which track days are you doing?
micksummer
Now I let air out to 30 frt 34 rear cold and do a few laps then let more air out. Once I get to 32/36 hot they tend to stay at that hot pressure for the rest of the day even if it cooled right down at long breaks.
The other "quirks" I found with the R888s are that when the pressure is still low before heating up, the steering vibrates a little but soon settles within a few corners, but when it gets hot the grips fall drastically, and become very "skittish" withing a few corners.
BTW, if the rubber gets overheated a few times (heat-cycles) it loses the grippiness even when there's plenty of rubber left, and the tyres become pretty much useless! (we found that out last wkend!)
rbignell
I run Toyo R888 on my 968 Sport Track Car. At a recent track evening I started off at 28/24 and throughout the evening and after each sesssion and looking at the wear pattern I ended up at running 32 all round. The evening was at Yas Marina (I live in the UAE) and temperture was I would say about 23 C. My car has quite aggresive suspension set up and is very stiff so I guess setting the pressure depends on the car, track, conditions and driving style. If you have not used Toyos before they are really fantastic and you will love evry minute you are in the car.
Ray
paul howells
I would try 32 allround hot to start with,toyo do like more pressure than most.
Vic has run them for a while now,he should know where they are at
see you friday
Also FWIW if weather roughly like it is /temps .........wud start abt 27/28 all round and deflate slowly ..............pump up if a long drive home or u ll have no tyres left !
