Tyre pressures
- Thread starter Guest
(29F/36R as well - and you shouldn't need to look it up, you should be checking often enough to know it off by heart [
ORIGINAL: princer2
Hi Guys new to this my first post. Have read in some car mag this week about using Nitrogen in the tyres, same as racing cars apparently, since it doesn't change pressure with temperature. A number of garages are supposed to offer this, anyone know anything about it ?
It should be 29F 36R for all wheel sizes if I recall.
plightbown
Peter
plightbown
Will check out again but 29/36 seems to be consensus
Pete
Analogue is more accurate in this case as the digital ones only show to the nearest 1 lb, or 1/2 lb, whereas you can see that it is spot-on or not with a dial.
www.demon-tweeks.co.uk
www.gprdirect.com
Thanks, Mark.
ORIGINAL: spyderman
That's more like it. Longacre 0-60psi with a nice white dial and a rubber surround for about £26 inc VAT and postage.
Thanks, Mark.
I bought one too..... BUT I dropped it and lost the calibration ... oopps!
pjwakefield
