Is there a sticker under your front boot lid? That's where ithe info is on mine. It should be 29F 36R for all wheel sizes if I recall.
Tyre pressures
- Thread starter Mark_Bennett
plightbown
Question please. I have 18" Carrera wheels on my 986, Dunlop ZR 18 Sport 9090 tyres, 265/35 on back and 225/40 on front. Can't find them on Dunlop website but wanted to check pressure guide. Boxster handbook is based on 17" rims. Does this make a difference?
Pete
Pete
plightbown
Thanks. Will check. Peter
plightbown
Thanks Gary Will check out again but 29/36 seems to be consensus Pete
All this talk of tyre pressures has got me wondering: where/how do I get hold of a pressure gauge that is accurate? Those built in to most cigarrette-light socket compressor thingies are useless since they max out at 200 or even 300psi, so telling the difference between 29 and 36 is almost impossible. Even 1 or 2psi will make a difference to these tyres and at circa £200 a pop, you want to get it right!
I got a good analogue (dial) display one from a motor racing supplier (either Demon Tweeks or Grand Prix Racewear) Analogue is more accurate in this case as the digital ones only show to the nearest 1 lb, or 1/2 lb, whereas you can see that it is spot-on or not with a dial. [link=http://www.demon-tweeks.co.uk]www.demon-tweeks.co.uk[/link] [link=http://www.gprdirect.com]www.gprdirect.com[/link]
Exactly the one I've got [
I bought one too..... BUT I dropped it and lost the calibration ... oopps!ORIGINAL: spyderman That's more like it. [link=http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=LON50401]Longacre 0-60psi[/link] with a nice white dial and a rubber surround for about £26 inc VAT and postage. Thanks, Mark.
