Hi All,
I have larger wheels on my car and was wondering if you should change tyre pressures if you are running lower aspect ratio tyres? Porsche say there should be 3.0 bar in the rears and 2.0 bar in the fronts. For the rears that means 43.5psi in each tyre and my continentals say a max pressure of 44psi. They sound over inflated to me but I assume that they should still carry this pressure as this is the pressure Porsche recommend. They do seem very high pressures to me, is this because the engine is in the rear?? A bit unsure of what pressures to run, any advice would be greatly appreciated! Cheers
Kristian
Kristian
