Tyre swap...2 or 4?
65 mat
Do people usually just swap the rears when they are worn and utilise the remaining tread left on the fronts, or do people swap all 4 at once? Is the later the better option for track use?
Cheers, Matt.
Personally i think you'd be fine swapping two as long as you get same make and type as rears
Thats a biy of a strange question Matt ! The only circumstance I can see where you would replace all 4 at once would be when you want to change the type of tyre you are running on. I'd certainly invest in an extra set of rims so that you can fit 2 different types of tyre eg sticky road legal Toyo R888's on one set and 'wets'/ 'normal road tyre that is trackable' on other set eg Michelin Pilot Sport PS2s.
Usual road use for 964RS means replace rears twice as often as fronts , spirited track use can turn this into replace fronts and rears together. HTH
