ORIGINAL: willstatt
When you say my tyre combination is "un-approved" what exactly do you mean? Do you mean that it is expressly advised against (for a particular reason?) or that it is simply not one of Pirelli's/Porsche's approved optimum setups, but that there is no reason why it can't be used.... if you get my drift?
what Porsche actually say is some what open some intrepretation in the real world if you consider the complexities of N rated tyres... as one of the key terms used is that Porsche
recommend that matching N rated tyres are used all the way around, but in the same way Porsche owners fit Pagid Brake Pads, whereas Porsche recommend fitting their OEM Pads....... I can understand and agree why 4 mixed tyres of any combo is wrong,
but the only exception to 4 matching n rated tyres that I see as permissable is if that all the tyres are at least of the same manufacturer and (obvious all n rated) by each axle has a different N rated spec e.g. you may have N4 Pirelli's on the rears and N3's Pirelli's on the front, etc etc and that is the only different front to rear, not side to side !
as when I bought my car, I had Contiential Sport N1's on the Front and Contiential Sport N2's on the back, and they were fine for the 10k miles thst they lasted, whch included a few track days as well... and I did not see the value in spend £400 to get fully matching tyres and if I had to change a tyre I would have kept to Conti's to ensure the right balance..
obvious if you can fit the same 4 N rated tyres all the way around this is the correct option, (which is what I have right now, Michelin Pilot Sport N2's so avoiding the multi-combo Pirelli options!) but I can understand if one tyre suffers a failure and you are faced with having to replace all 4 tyres as your current N spec is no longer available, afterall we are not all millionaires who drive their cars at the performance limit all the time !
I don't know it they have actually said the unword unapproved unless Maurice would care to enlighten us ?
to aid in this debate.... here is an exact from an artcile from a US Tyre (they spell it Tire!) site
It is recommended that only matching tires be used on Porsche vehicles. Since many Porsche vehicles are fitted with differently sized tires on their front and rear axles, this means matching the tire make, tire type and N-specification. If a vehicle was originally delivered with N-specification tires that have been discontinued and are no longer available, it is recommended to change all four tires to a higher numeric N-specification design appropriate for that vehicle. Mixed tire types are not permissible.
It is also important to know that while Porsche N-specification tires have been fine tuned to meet the specific performance needs of Porsche vehicles, the tire manufacturers may also build other tires featuring the same name, size and speed rating as the N-specification tires for non-Porsche applications. These tires may not be branded with the Porsche N-specification because they do not share the same internal construction and/or tread compound ingredients as the N-specification tires. Using tires that are not N-specific is not recommended and mixing them with other N-specification tires is not permissable.
Tires should be replaced no less than in pairs on one axle at a time. Only tires of the same tire make and type must be used. However, in case of tire damage such as cuts, punctures, cracks or sidewall bulges that cause a single tire to be replaced for safety reasons, the remaining matching tire on that axle must not exceed 30 percent wear. If the remaining tire has more than 30 percent wear from new, it should also be replaced. Handling inconsistencies may result if this is not done.
Initially, new tires do not offer their full traction. Drivers should therefore drive at moderate speeds during the first 60-100 miles (100-200 km). If new tires are installed on only one axle, a noticeable change in handling occurs due to the different tread depth of the other tires. This happens especially if only rear tires are replaced. However, this condition disappears as new tires are broken in. Drivers should adjust their driving style accordingly.
NOTE: The last two paragraphs are excerpts from recent Porsche vehicle owner's manuals.
