Porsche tyre policy from the forum FAQ Mixing N-Spec Tyres Use only tyre types tested by Porsche. Only tyres with the same manufacturer and with the same specification code (e.g. "N0", "N1" …) should be mounted on the vehicle. Tyres should be replaced no less than in pairs on one axle at a time. Only tyres of the same tyre make and type must be used. Since many Porsche vehicles are fitted with different sized tyres on their front and rear axles, this requires matching the tyre brand, tyre name and N-specification front to rear. While the tyre manufacturers may also build other tyres featuring the same name, size and speed rating as the N-specification tyres for non-Porsche applications, these tyres may not be branded with the Porsche N-specification because they do not share the same internal construction and/or tread compound ingredients as the N-specification tyres. Replacing N-Spec Tyres If a vehicle was originally delivered with N-specification tyres that have been discontinued and are no longer available, it is recommended to replace all four tyres to a higher numeric N-specification design appropriate for that vehicle. In case of tyre damage such as cuts, punctures, cracks or sidewall bulges that cause a single tyre to be replaced for safety reasons, the remaining matching tyre on that axle must not exceed 30 percent wear. If the remaining tyre has more than 30 percent wear from new, it should also be replaced. This rule applies to all four tyres on all wheel drive vehicles. Handling inconsistencies may result if this is not done.
