Tyres
- Thread starter kitchens
Read this, it will explain the N rating bit: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=26
The Porsche N rating isnt related to speed a tyre's speed rating, thats T or Z rating etc.ORIGINAL: kitchens
I understand about the same tyres on the same axle but was wondering about the N4 /N2 on the car though all had to be the same speed rating
My understanding is that as each revision of a manufacturers tyre model (e.g. Michelin Pilot Sport) is approved, then the N rating is increased accordingly with that tyre. So N0, N1, N2, N3....
ORIGINAL: TopBear
Ditto, as mentioned in paragraph 5 in the link I posted. It is worth reading that webpage again.
Dapster
Continental n2 sport 365/18/ZR 35
How wide!?
watlina
http://en.wikipedia.org/wiki/Siping
http://www.sipers.com
But I suspect if it was that good the manufactures would do as standard to all tires
I have generally replaced 'like for like' with Continental Sport Contacts, but need to change all 4 so would like views on what to go for - I dont track the car, just 'quick' road use - was considering P Zero Rosso's - but are there any views or alternative suggestions please (Michelin, Bridgestone etc etc)?
Thanks!
Black80XSA
I would go for Continentals. They aren't quite as grippy as Pirelli (not far off though) but last longer and are far quieter. (I've found the Pirellis roar like crazy on certain tarmac). The Contis are also about the cheapest 'proper' option. As a little more rear grip and traction can never be a bad thing, why not go for the 285s? They also look better on the rims than the 265s. I always think that 265s look a little 'stretched' as if the rims are just that bit too wide for the tyre!
Regards 17" wheels, only my opinion, but I think they look too small on a 996. The 18" Carrera alloy looks the business though and is also very light.
pwafer
My only other comments on the 18" Carreras is if you are trying to go for long life, then Michelin Pilot Sports are probably the best, but also the most expensive.
I wouldn't consider the 265 width for one very important issue, if you do rub a curb, you'll hit the alloy and not the tyre, my 285's on the rear (Michelin PS's) have a nice rim protector (as do the fronts).
