Can anyone PLEASE confirm the correct tyre size for a c4s and recommend longer lasting Tyres?. I currently have conti sp2 225/40 zr18 and 295/30 zr18.
Thanks a lot Richard. What's your views on Bridgestone?ORIGINAL: Richard Hamilton Yes, you have the correct tyre sizes. Here we go again............. I found that the Conti SC2s on the rear of my Turbo wore out alarmingly quickly (2 pairs at 3000 miles per pair), but others have said they were fine for wear. I switched to Yokohama Advan Sport V103s, which were great, but they aren't N rated (if that bothers you). Michelins are usually the best all-rounders, but the most expensive. (Awaits other recommendations).
Thanks Paul. Are they SC2's? I had these on my 993 and they were ok but I am told Bridgestone's will last longer. Not sure.ORIGINAL: kasspa Hi Seb, As Richard has confirmed, you have correct sizes..... I have N2 Contis on my '04 4S & have found them to be excellent for both traction & wear! Currently have covered approx 16k+ miles with them & nowhere near wear indicators[] hth Paul
[][]Bridgestones and Firestones make great Flower pots on travelers sites.
Never noticed personally, cannot afford to visit & expensive to park[]quote: Bridgestones and Firestones make great Flower pots on travelers sites.
Thanks Mike, can I ask what Bridgestone were they?ORIGINAL: Sam Quick Hi I'm running bridgestones all corners. I've changed the rears after 12000 and the fronts recently at 15000, there was still life in the fronts but all cracked in the treads so moved them on. Have not had any handling issues and great in the wet. Fronts 130.00 and rears were 220 each. Cheers[]
