My 911 SC has 215 60 15 tyres on the rear, what problems if any arise if I fit 225 60 15. This tyre is 20mm wider will it affect the handeling or the speedo reading. Any advise would be welcome.
Tyres
- Thread starter adriandavidson
A wider tyre of the same profile and radius will have a greater rolling radius so better to come down a little in profile size to reduce any affect on the speedo - 225 60 15s will under read on the speedo. 225 55 15 in a decent speed rating are unusual but 225 50 15 have a few choices in V or better rating (try blackcircles.com). Fitting 225s per se should be no problem, 225 50 16 is the standard size tyre on the rear of the SC Sport so there should be plenty of room under the wheel arch. You will probably won't get a great deal of benefit from making the change to 225 60 15, but similarly no untoward effect either apart from the slightly higher overall gearing. Dave Jones
