Uneven tyre wear
- Thread starter Guest
This is the wear I would expect if so.
Funny how they always seem to scrub out on the inside. I don't recall having tyres wear the outside edges first - not since my Mini days, anyway.
I guess it's not unusual for the alignment to get out of shape, bearing in mind all the speed bumps around here!
Thanks again,
Justin
When I traded it in, the dealer specifically looked at the inside edges. I believe they wear the inside edges more quickly due the standard setup with a some camber.
If you throw it around corners a lot, I think the wear would be reasonably even, but I do lots of A-road/motorway miles, so they don't get the edges scrubbed that much.
The inside was below the legal limit, the outside had about 3mm.
Grant
