I've got my dash apart at the moment; before I pull the pipe out, whats on the other end? It feels like its disconnected but maybe it should just hang in space? Is the sensor plugged in to the other end and if mine is disconnected presumably the glove compartment has to come apart to find it?
Unknown pipe
- Thread starter sib8292
A little fan draws cabin air through it to measure for temperature so the automatic control can work correctly. If it is not connected nothing terrible happens, but you probably find the heating doesn't maintain a constant temperature. When it works it's excellent, to the point I didn't have to adjust the temp to compensate for roof up or down in the cab.
944cabby
Is this the circular "slotted vent" thing on the left of the centre console by ciggy lighter?If so is it much to replace 'cause i think mine might be buggered - i like the heat full on in the cab but just lately it's been making me eyes hurt![ORIGINAL: Fen
Yes, that's the vent. On the 968 forum someone posted they are about £6 for the grill if that's what's broken. If it's not working then drop the govebox liner and check the pipe is connected at both ends. I haven't heard of it fail, but in my cab temp control didn't work at first which turned out to be a trapped vacuum pipe in the blower assembly in the scuttle.
ORIGINAL: sib8292
Fen thanks; ok but what should be at the other end of the pipe ie nearest the bulkhead? and assuming that it should connect to something how do I get at it to re connect? I can see that the end nearsest the cockpit should fit on to the back of the trim!
