I've exhausted the search and can't find an answer to this problem.
I took the car out today for the first time after my new paint job and it's decided to play up. It ran fine until it got up to temperature, then kangaroo'd at constant low throttle openings and just cutout when coming up to roundabouts with no throttle. Basically it wouldn't run at less than around 2000rpm.
I've checked and there are no vacuum leaks that I can see, I've cleaned the ISV and Air Flow sensor thinking they may have gummed up. I didn't manage to get the black cap off the air flow sensor as I wasn't sure how to. It seems pretty well stuck on.
I did happen to notice that the tamper proof plug on top of the sensor was missing! I'm hoping someone who knew what they were doing made some adjustments in the cars previous life. But that's been like that all the time I've had the car.
The only link that I could find that had anything to do with temperature from my search was a mention of cylinder head temp sensor, Not sure what that really does or where it is. Could it be that?
Any thoughts? Anything I should be looking for?
