Thanks for all of the comments so far.
Latest situation is that my car went into Reading OPC to investigate a grinding noise in the front end which turned out to be a front diff bearing (front diff being replaced under warrenty), however when the mechanic took the car out for a test drive he commented on my car's wandering tendencies. His conclusion was, yes, you need to replace the tyres, but, there was no question that the car needed a four wheel alignment also. When the OPC checked this out for me a month or so before, they said this was not neccessary! The mechanic (who was great by the way) also recommended I replace the Pirelli's with Michelin tyres as they are quieter and handle better.
So, my cunning plan is to firstly have four new Michelin Pilot Sports fitted next Saturday and then, have the alignment done - I will let you all know which solution makes the biggest impact and answers the question!
