MJL944
The little fan on the interior temperature sensor unit (which sits behind the glove-box) on my 1989 S2 makes a very irritating buzzing noise at all times - especially on start-up. By placing my finger on the fan to stop it rotating I can kill the buzzing noise.
How do you remove the unit?
Can it be removed without removing the glove-box first?
Once removed, would spraying some white grease or WD-40 into the fan spindle area stop the buzzing noise or is a new interior temp sensor unit the only solution?
Maybe a new fan can be bought separately?
Or, is the noise due to the fan & unit being all clogged up with dust?
I've been told a complete new unit is around £100 so a quick squirt of some magic spray & a clean up would be a much preferred solution!
Hopefully someone out there will have dealt with this problem.
Many thanks.
Many thanks.
