Gentlefolk,
Probably a question for the turbo tuners, does anyone know of an "uprated" ignition system that might work on a 944 S2?
Following the Dyno day I am reasonably confident that the Ignition system on my S2 is relatively healthy - I certainly have new plugs, leads, dizzy cap and rotor arm etc, and it runs fine. However... LPG seems to be somewhat more demanding on the ignition system, so whilst it works fine on petrol, I wonder if this is possibly part (if not all) of the problems I have of a high-speed miss-fire on LPG.
Ideally, I don't want to replace the LT side, just the HT side, so am thinking I guess of a go-faster coil. I seem to recall "WUF" had a coil per plug, but does this require an entirely different ignition "brain" or other major changes?
My reason for looking at the ignition system is two fold - firstly the majority of poor running problems that I have seen solved in LPG conversions seem to be the ignition system rather than the LPG system itself, and years ago a discussion with Jon Mitchell, and his commenst that he would like to see what difference a twin-spark conversion to a 944 might make to it's performance... this stuck in my mind in terms of perhaps the existing arrangement might not be ideal in the combustion chamber, and of course, LPG will have entirely different burn characteristics.
Any suggestions gratefully received!
