NutsyH
Hi all. Just tried to top up the adblue tank from the pump at my local garage. Nozzle goes in filler neck ok, but will not pump fluid. Pull the lever, pumps 0.2 litre then stops. Tried the other pump, same result. Garage man tried, same result. He says the pump is sensing that the tank is full and doing the auto stop function. Tank is low - 5500 miles since last fill by OPC.
Has anyone else had this problem? I don't want mess about filling from 1 ltr containers, not least because it is twice as expensive as well as a hassle.
Any ideas please?
Paul
Any ideas please?
Paul
