Right, I am full of questions at the moment. I am after some new vac lines from the wastegate to the banjo bolt via the MBC but I dont know what to buy. The wastegate and my MBC have small take offs but the Banjo bolt has a large take off.
The old line is small at the wastegate then runs into a larger size line before conecting to the valve under the manifold.
I guess if the inner dia of the lines is a bigger size then normal then the wastegate will open later
So question is where do I buy lines from?
