Vacuum Hose Kit
- Thread starter Riggernut
sawood12
Another nice bit of kit that was popular on Rennlist is a small manifold. This means you don't have to route all your pressure lines around the engine as per the way they currently are and that all pressure lines come from one manifold. It minimises joints and hence opportunities for leaks, minimises the length of hose used, tidies up the engine bay and makes it easier to trace any boost leaks. From what I could gather from a photo of one it was just a short length of aluminium square or rectangular section bar with a blind hole drilled down its length. At the end was the pressure input from the Banjo bolt take-off and there were 5 holes drilled and tapped along two of the long sides where pressure take off points could be taken. A nice little project for someone who want to make one.
robwright
