Black Beauty
Hi,
My 84' Lux is overfuelling and I have replaced / tested everything, however, I am now convinced as much as I can be that I may have a vacuum leak as there is an odd sound from near the inlet manifold, however, I'm not really sure how I go about testing for a leak.
The vacuum pipes that go from the FPR and dampner to the throttle body have been replaced a couple years back, but are there any other smaller ones that I need to check?
I am convinced that is coming from near the inlet manifold, but I am not sure how and where to check or what tools to use?
One other thing and something I've never noticed before but may be linked, is that when I take the Oil filler cap off when the engine is running the rev's drop, thinking I was hearing things and/or it was just co-incidence I took it off again, and the revs dropped again. Does this point to an issue elsewhere?
Everything else on the car is fine, she idles' well, pulls ok except that she' does backfire when I let off the gas checking
Spence
Spence
