Keggers
Hi
I have discovered that one of my vacuum lines in behind the resonance flap seems to have come out. There is no vacuum coming to the solenoid valve next to the alternator, so I traced the line back and noticed that it joins a three way connector behind the resonance flap pipe. The line from the solenoid valve is plugged in fine. The second connector seems to go to the vacuum cannister. The third connector seems to have plugged nothing in it. Its very difficult to see clearly in there as to whether there is a loose line hanging around there that should be plugged into the connector.
So I have two questions:
1. What impact will having no vacuum coming through this line (and the vacuum cannister being unable to create a vacuum due to the open connector) on the running of the engine?
2. Is there an easy way to get in there to access the connector without removing the throttle and the two pipes? I've done this before to install my PSE (which is probably when I knocked the line out!!) and it was a very hard job to get the two pipes back on.
Greg
Greg
