tail_heavy
Does anybody have any experience of getting the vacuum headlight adjustment to work? Car is a 87 UK spec 3.2. I'm not sure how common this fitment is on UK cars, but it does not appear to have been an option in the US, so it doesn't feature in the Bentley manual. From what I can make out, it's 100% vacuum operated with no electrical control. A connection to the main vacuum service pipe for the brake servo runs to the (sideways on) rotary control next to the headlight pull switch which appears to vary the vacuum that is then passed to two diaphragms, one on each headlight. These then adjust the vertical position of the headlight via a little pushrod acting against a spring. There is also a little vacuum reservoir that presumably smooths out fluctuations in the (negative) pressure. Thing is, a) mine doesn't work and b) I can't really understand how it could work. Surely, if the rotary control is just a valve controlling the vacuum, the full vacuum would eventually build no matter which position it was in. Also, unusually compared to systems in modern front engine cars, the control gives the option to raise the headlights (by one notch) as well as lower them - presumably to offset the effect of a heavy weight in the boot.
This seems like a typical 80s bizarre Porsche solution to a simple problem. Wouldn't it have been better to have some nice, heavy, electrical stepper motors in the headlamp shells?!
This is the least critical of my 3 requests for help this evening, but I'd like to know more about this strange system.
