valve adjustment
- Thread starter Guest
AirCooledExcellence
Clearances should be checked when stone cold (preferably left overnight). It sounds as if they need doing, they are probably within limits when the engine is cold but go out once everything starts expanding.
It's a fairly easy (2 hour) DIY job if you are that way inclined!
Cheers,
Tim.
Look here for a step by step proceedure for valve clearance adjustment.
www.pelicanparts.com look in the technical section. Also do not remove the plugs to aid turning over the engine as carbon could fall onto the valve seat and give you a false reading. I bought a special tool which holds the clearance shim from the Porsche shop, this tool is shown in the pelican proceedure photo's.
John, from the SC forum
