robsangster
Full story to follow - but for all of you busy doing summer tinkering, LED upgrades, TLC etc etc...... before you do anything else, check your valve springs! Only 5,000miles before the outer spring failed on this car it was treated to a FULL service inc, all belts, water pump, tensioners and rollers, cam chain, slipper pad (both pads) and new hardwear and rubber/gaskets were appropriate.
Several - coughs and splutters were the first indication of anything wrong when cold .... but these soon past - and just as a precaution the distributor, rotor and leads were changed (while we are here the car only ever had genuine OPC supplied parts).... all seemed ok...... until BANG
I will put more up on this thread soon - but broken cam belt is not the only way to loose the heart of your beast - trust me - the attached pic is from my car. It has created a real mess and on removing the head I have discovered that ANOTHER outer spring was also broken - but had not yet manifested further.
Car (was) a 1991 S2 Cab with 90,000 genuine miles, full history from AFN and the best Indies in later life, no fewer than 4 cam belt services, all MOTs and servicing above and beyond Porsche's recommended schedule...... and still this!
If your S2 ever so much as misses a beat - get that cam cover off and run your finger over those springs!!!!!!
I now have the task of sourcing a replacement motor (have been for a while now) - that is already proving to be an utter mine field - amazing how every second hand unit has less than 100,000 miles - but sadly no history to back that up.
Like I said more pics to follow later some time - but yes the piston was PUNCTURED too!!
![49BD426429E64F7980A4C3FBA9604FBA.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/18303/49BD426429E64F7980A4C3FBA9604FBA.jpg)
