Valve stem oil seals
- Thread starter idc1873
I do not have an answer but my question is can the seals be replaced without removing the heads. I would be interested if anyone has tried holding the valves closed with air pressure, some sort of probe down the plug hole or even letting them rest on the piston at TDC. If this was possible what sort of tool is needed to compress the valve springs.
dtunnicliffe
Such a tool as Joan speaks of was made for Ford engines years ago but I know of no such tool for Boxer engines (flat six). you might call Neil Bainbridge over at BS Motorsport for an HONEST answer. He's a fine engineer by the way..
Dave
![Spanner 3 [sm=spanner3.gif] [sm=spanner3.gif]](/forum/styles/default/pcgb/spanner3.gif)
ORIGINAL: dtunnicliffe
I still have the Ford tool for pintos, OHV's and CVH engines in my tool box. If some one has a head off and engine we could find out if it would work on it. I also have the DOHC (ford) tool for removing valve springs.
Another method was turning the enging till TDC on the compression stroke and then filling the cylinder with compressed air. As long as there is some spare room around the engine there is no reason why this would not work on a 911
I am pretty certain that mechanics in the USA have changed valve springs without removing the heads so ask the specialists. Try Autofarm and companies like that.
